Displays information about VRs and VRFs.
| name | Specifies the name of a VR or VRF. |
N/A.
The following example displays the VR and VRF configurations on the switch:
# show virtual-router
Virtual Number of Number of Flags
Router VLANs Ports
VR-Control 0 0 --------S46
VR-Default 32 18 boprimORS46
xvr 1 0 b-------F46
VR-Mgmt 1 0 --------S46
Flags: Routing protocols configured on the Virtual Router
(b) BGP, (i) ISIS, (m) MPLS, (o) OSPF, (O) OSPFv3, (p) PIM,
(r) RIP, (R) RIPng.
Virtual Router type
(D) Dynamically created user VR, (F) Non-VPN VRF, (N) VPN VRF,
(S) System, (U) User.
Virtual Router admin state
(-) Disabled (4) IPv4 Enabled, (6) IPv6 Enabled.
System Totals :
Total VRs : 4 Max VRs : 1066
Total User VRs : 0 Max User VRs : 63
Total Non-VPN VRFs : 1 Max VRFs : 1000
Total VPN VRFs : 0 Total System VRs : 3
Total Protocols : 8 Max Protocols : 64
Max IPv4 VLANs : 4096 Max IPv6 VLANs : 1024
Total IPv4 VLANs : 13 Total IPv6 VLANs : 8
Active IPv4 VLANs : 12 Active IPv6 VLANs : 8
Inactive IPv4 VLANs : 1 Inactive IPv6 VLANs : 0
The following example displays information about VR-Default:
# show vr VR-Default Virtual Router : VR-Default Type : System Description : Default VR Operational State : Up IPv4 Admin State : Enabled IPv6 Admin State : Enabled IPv4 Route Sharing : Disabled IPv6 Route Sharing : Disabled L3VPN SNMP Traps : Disabled Protocols Configured : -------------------------------------------------------------------------------- Protocol Process Configuration Protocol Name Name Module Name Instances -------------------------------------------------------------------------------- BGP bgp bgp 1 OSPF ospf ospf 1 PIM pim pim 1 RIP rip rip 1 ISIS isis isis 1 OSPFv3 ospfv3 ospfv3 1 RIPng ripng ripng 1 -------------------------------------------------------------------------------- Port List : 1-34 VLANs : Default Virtual Router Totals : Total Protocols : 7 Max Protocols : 8 Total Ports : 34 Total VLANs : 1 Total IPv4 VLANs : 0 Total IPv6 VLANs : 0 Active IPv4 VLANs : 0 Active IPv6 VLANs : 0 Inactive IPv4 VLANs : 0 Inactive IPv6 VLANs : 0
The following example displays detailed information for a VRF:
# show virtual-router xvr Virtual Router : xvr Type : Non-VPN VRF IPv4 Admin State : Enabled IPv4 Forwarding : Enabled IPv6 Admin State : Enabled IPv6 Forwarding : Enabled Operational State : Up IPv4 Route Sharing : Enabled IPv6 Route Sharing : Disabled Parent VR : VR-Default Protocols Configured : -------------------------------------------------------------------- Protocol Process Configuration Protocol Name Name Module Name Instances -------------------------------------------------------------------- BGP bgp bgp-3 2 -------------------------------------------------------------------- VLANS : xlan Virtual Router Totals : Total Protocols : 1 Max Protocols : 8 Total Ports : 0 Total VLANs : 1 Total IPv4 VLANs : 1 Total IPv6 VLANs : 0 Active IPv4 VLANs : 1 Active IPv6 VLANs : 0 Inactive IPv4 VLANs : 0 Inactive IPv6 VLANs : 0
The following example displays information for user VR region1:
Router VLANs Ports
uservr-1 26 0 bo---m--U46
xxx 1 0 b-------N46
VR-Default 12 14 bopri-ORS46
Flags : Virtual Router Type
(S) System, (U) User, (F) Non-VPN VRF, (N) VPN VRF
(L) Local-only for switch‘s local IP addresses
: Virtual Router Admin State
: Routing protocols configured on the virtual router
(b) BGP, (i) ISIS, (m) MPLS, (o) OSPF, (p) PIM, (r) RIP,
(O) OSPFv3, (R) RIPng
System Totals :
Total VRs : 5 Max VRs : 1066
Total User VRs : 1 Max User VRs : 63
Total Non-VPN VRFs : 0 Max VRFs : 1000
Total VPN VRFs : 1 Total System VRs : 3
Total Protocols : 10 Max Protocols : 64
Total IPv4 VLANs : 19 Total IPv6 VLANs : 9
Active IPv4 VLANs : 18 Active IPv6 VLANs : 9
Show virtual-router detail for a user created VR
# show virtual-router "uservr-1"
Virtual Router : uservr-1 Type : User
IPv6 Admin State : Enabled IPv6 Forwarding :Enabled
BGP bgp-5 bgp-5 2
OSPF ospf-5 ospf-5 1
MPLS mpls-5 mpls-5 1
VRFs Configured :
Virtual Flags
Router
xxx b-------N46
Route Exports into L3VPN (BGP):
VPN VRF Route Type Flags Priority
Policy
xxx Direct EO 2048
None
vpn2 Static EO 2048
None
Flags: (E) Export Enabled, (L) Export Operationally Off due to Low Memory,
(O) Export Operationally On
VLANS : foo1, foo10, foo11,
foo12,foo13, foo14,
foo15,foo16, foo17,
foo18,foo19, foo2,
foo3, foo4, foo5,
foo6, foo7, foo8,
foo9, lan-uvr-1, lo,
lo-uvr-1, v77, v88,
vlan1, vlan2
Total Non-VPN VRFs : 0 Total VPN VRFs : 1
Total Protocols : 3 Max Protocols : 8
Total Ports : 0 Total VLANs : 26
Total IPv4 VLANs : 7 Total IPv6 VLANs : 1
Active IPv4 VLANs : 7 Active IPv6 VLANs : 1
Show virtual router for a VPN VRF t16.2 # sh virtual-router "xxx"
Virtual Router : xxx Type : VPN VRF
Parent VR : uservr-1
VPN ID :
VPN RD : 1:1
Export RT : 1:1
Import RT : 1:1
BGP bgp-5 bgp-3 2
Policy
xxx Direct EO 2048
None
VLANS : xlan
The current and configured values for max-gateways now apply to IPv6 gateway sets as well as IPv4, so these values are added to the output of show ipconfig ipv6.
# show virtual-router Virtual Number of Number of Flags Router VLANs Ports -------------------------------------------------------------------------------- VR-Boston 2 2 --------U46 VR-Control 0 0 --------S46 VR-Default 1 278 boprimORS46 VR-Mgmt 1 0 --------S46 -------------------------------------------------------------------------------- Flags : Virtual Router Type (S) System, (U) User, (F) Non-VPN VRF, (N) VPN VRF (L) Local-only for switch‘s local IP addresses : Virtual Router Admin State (-) Disabled (4) IPv4 Enabled, (6) IPv6 Enabled : Routing protocols configured on the virtual router (b) BGP, (i) ISIS, (m) MPLS, (o) OSPF, (p) PIM, (r) RIP, (O) OSPFv3, (R) RIPng System Totals : Total VRs : 4 Max VRs : 256 Total User VRs : 1 Max User VRs : 63 Total Non-VPN VRFs : 0 Max VRFs : 190 Total VPN VRFs : 0 Total System VRs : 3 Total Protocols : 8 Max Protocols : 64 Max IPv4 VLANs : 512 Max IPv6 VLANs : 512 Total IPv4 VLANs : 0 Total IPv6 VLANs : 0 Active IPv4 VLANs : 0 Active IPv6 VLANs : 0 Inactive IPv4 VLANs : 0 Inactive IPv6 VLANs : 0 Max Shared GWs (Cur) : 32 Max Shared GWs (Cfg) : 32
A command similar to this command was available in ExtremeXOS 10.1 (show vr).
This command was first available in ExtremeXOS 11.0.
Support for non-VPNVRFs was added in ExtremeXOS 12.5.
The show output for max-gateways was added in ExtremeXOS 15.3.
The "L" flag was added to signify local-only VRs in ExtremeXOS 22.6.
The "D" flag was added to show if a VR is created dynamically in ExtremeXOS 30.4.
